Running External Script in Zabbix
  • sjbalaji
    • Aug 2008
    • 33
    Hi All,
    i need to run external script in zabbix monitoring
    There is any document to run the external script through zabbix ?
    Any suggestion ?
    Thanks in Advance.
  • alixen
    • Apr 2006
    • 474
    Originally posted by sjbalaji
    Hi All,
    Any suggestion ?
    Thanks in Advance.
    Documentation for external checks (external script on the server):
    http://www.zabbix.com/documentation/...xternal_checks
    Documentation for user parameters (external script on the client):
    http://www.zabbix.com/documentation/...ser_parameters
    Hope this helps
    Alixen
    http://www.alixen.fr/zabbix.html
    • sjbalaji
      • Aug 2008
      • 33
      Hi All,
      I read the doc given by alixen,but its little confusing.
      Is there any other docs for running external oracle sql plus script through zabbix ?
      Thanks in Advance.
      • sjbalaji
        • Aug 2008
        • 33
        Hi MrKen,
        can you please help me to sort out the issue ?
        • trikke
          • Aug 2007
          • 140
          How about this:
          create a shell script like this :
          #!/bin/sh
          if [ $# -lt 1 ]
          then
          echo "Please provide ORACLE SID "
          echo "e.g. $0 DBxy"
          exit
          fi
          ORAID=$1
          PATH=/u00/app/oracle/product/10.2.0.4/bin:$PATH
          export PATH
          ORACLE_HOME=/u00/app/oracle/product/10.2.0.4
          export ORACLE_HOME
          conn=`sqlplus -S user/pwd@$ORAID <<INPUT_DATA
          set serveroutput on FORMAT WRAPPED;
          set feedback off;
          set verify off;
          <put sql code here>
          quit;
          INPUT_DATA
          echo "${conn:=panic}"
          exit
          and run this as external script!
          • sjbalaji
            • Aug 2008
            • 33
            Hi Everybody,
            Please anyone can guide me to set User Parameter value need to set for execute the above script?
            Also the value for item and trigger ?
