template seems don't work in 1.6.7
  • fanchao
    • Jan 2010
    • 12
    I use zabbix to monitor Squid Server via snmp (oid .1.3.6.1.4.1.3495.1.3.* ) .
    The template is wrote like below
    <zabbix_export version="1.0" date="20.08.09" time="11.55">
    <hosts>
    <host name="Temp_Squid01">
    <useip>0</useip>
    <dns></dns>
    <ip>0.0.0.0</ip>
    <port>10050</port>
    <status>3</status>
    <groups>
    </groups>
    <items>
    <item type="4" key="MemUsage" value_type="3">
    <description>Total memory accounted for KB</description>
    <ipmi_sensor></ipmi_sensor>
    <delay>60</delay>
    <history>90</history>
    <trends>365</trends>
    <status>3</status>
    <units></units>
    <multiplier>1</multiplier>
    <delta>0</delta>
    <formula></formula>
    <lastlogsize>0</lastlogsize>
    <logtimefmt></logtimefmt>
    <delay_flex></delay_flex>
    <params>DSN=&lt;database source name&gt;\nuser=&lt;user name&gt;\npassword=&lt;password&gt;\nsql=&lt;query &gt;</params>
    <trapper_hosts></trapper_hosts>
    <snmp_community>public</snmp_community>
    <snmp_oid>.1.3.6.1.4.1.3495.1.3.1.3.0</snmp_oid>
    <snmp_port>161</snmp_port>
    <snmpv3_securityname></snmpv3_securityname>
    <snmpv3_securitylevel>0</snmpv3_securitylevel>
    <snmpv3_authpassphrase></snmpv3_authpassphrase>
    <snmpv3_privpassphrase></snmpv3_privpassphrase>
    </item>
    I added hosts, but all the values got were "0"
    Use "tcpdump", i got these message
    10:35:42.503479 IP 21.161.251.27.47694 > napq01.letras.ufmg.br.snmp: GetRequest(33) E:3495.1.3.2.1.15.0
    10:35:42.504669 IP napq01.letras.ufmg.br.snmp > 201.11.51.27.47694: GetResponse(34) E:3495.1.3.2.1.15.0=[|snmp]
    10:35:43.911286 IP 21.161.251.27.47335 > napq01.letras.ufmg.br.snmp: GetRequest(32) E:3495.1.3.1.5.0
    10:35:43.912464 IP napq01.letras.ufmg.br.snmp > 201.11.51.27.47335: GetResponse(33) E:3495.1.3.1.5.0=1
    10:35:44.033528 IP 21.161.251.27.59377 > napq01.letras.ufmg.br.snmp: GetRequest(34) E:3495.1.3.2.2.1.2.60[|snmp]
    10:35:44.034632 IP napq01.letras.ufmg.br.snmp > 201.11.51.27.59377: GetResponse(35) E:3495.1.3.2.2.1.2.60=[|snmp]
    10:35:45.899145 IP 21.161.251.27.59756 > napq01.letras.ufmg.br.snmp: GetRequest(33) E:3495.1.3.2.1.12.0
    10:35:45.900368 IP napq01.letras.ufmg.br.snmp > 201.11.51.27.59756: GetResponse(37) E:3495.1.3.2.1.12.0=[|snmp]
    10:35:46.120848 IP 21.161.251.27.43817 > napq01.letras.ufmg.br.snmp: GetRequest(32) E:3495.1.3.1.3.0
    10:35:46.121967 IP napq01.letras.ufmg.br.snmp > 201.11.51.27.43817: GetResponse(36) E:3495.1.3.1.3.0=[|snmp]
    10:35:47.993204 IP 21.161.251.27.42731 > napq01.letras.ufmg.br.snmp: GetRequest(33) E:3495.1.3.2.1.13.0
    10:35:47.994448 IP napq01.letras.ufmg.br.snmp > 201.11.51.27.42731: GetResponse(36) E:3495.1.3.2.1.13.0=[|snmp]
    i cannot find out where the problems are !
    Any help? Thanks !
    Sorry for my bad english, i am Chinese.
  • fanchao
    • Jan 2010
    • 12
    B.t.w
    Does the zabbix_agent must be installed on the Squid Server ?
    [root@fan ~]# snmpget -v 2c -c public 115.14.100.65 .1.3.6.1.4.1.3495.1.3.1.3.0
    SNMPv2-SMI::enterprises.3495.1.3.1.3.0 = INTEGER: 9308363
    • MrKen
      • Oct 2008
      • 652
      If you plan to monitor by snmp then you don't need to install the zabbix agent.
      From your template above:
      key="MemUsage"
      That will never work, because the OID doesn't match the Key.
      .1.3.6.1.4.1.3495.1.3.1.3.0 = cacheSysDefReads
      That means key=cacheSysDefReads
      MrKen
      • fanchao
        • Jan 2010
        • 12
        Thank you MrKen .
        I have found out where the problem is, it's not because of the wrong key, and the key can be anything you want !
        It's the "formula". Here it should set to "1024".
        I had another question, now, How can I know the right way to set these options, like "type", "Value_type", "formula" ?
        Any documentation available ?
