Why do some items are not updated?
  • bashman
    • Dec 2009
    • 432
    Why do some items are not updated?.
    I have the same configuration for the items, and I have the same items for some hosts.
    Can someone help me please?.
    Thanks.
    978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
  • MrKen
    • Oct 2008
    • 652
    Are the items supported on the failing hosts?
    Any error messages on Conf --> Items page?
    Any errors in zabbix_server.log?
    If using zabbix agent, test the items using zabbix_get from the zabbix server.
    MrKen
    • bashman
      • Dec 2009
      • 432
      Hi MrKen,
      Thanks for writting so fast. I response your questions:
      Q: Are the items supported on the failing hosts?
      A: Yes
      Q: Any error messages on Conf --> Items page?
      A: No
      Q: Any errors in zabbix_server.log?
      A: No
      I get updates for these items but not in the update interval (30 seconds). The items update in days. I used zabbix_get from the zabbix server and items are ok. I think it could be a process problem, the mysql has only one process and has taken already half CPU uptime. The process is all the time on one processor.
      Number of hosts (monitored/not monitored/templates) 189 46 / 77 / 66
      Number of items (monitored/disabled/not supported) 1546 1384 / 82 / 80
      Number of triggers (enabled/disabled)[true/unknown/false] 705 627 / 78 [7 / 71 / 549]
      Number of users (online) 15 4
      Required server performance, new values per second 74.3307 -
      Could the problem be the zabbix db?.
      Thanks again MrKen .
      • MrKen
        • Oct 2008
        • 652
        Have you tried increasing the number of Pollers/Trappers in your zabbix_server.conf? (Don't forget to restart)
        MrKen
        • bashman
          • Dec 2009
          • 432
          Thanks Mrken I'll give it a try, by the way I get this log entry on the monitored hosts:
          2126:20100111:094900 Got SIGPIPE. Where it came from???
          Do you know what it means?
          • bashman
            • Dec 2009
            • 432
            I found the meaning of SIGPIPE:
            • elvar
              • Feb 2008
              • 226
              Thanks.
              I've spent a lot of time in the last month working on issues with various hosts / items not getting updated and it all came down to the backend database not being correctly optimized / configured. This may or may not be your problem but I figured I would at least make mention of it. I highly recommend checking out http://www.zabbix.com/forum/showthre...sql+consultant if you are using Mysql.
              • bashman
                • Dec 2009
                • 432
                I tried increasing the number of Pollers/Trappers in my zabbix_server.conf, but still doesn't work.
                I upgraded to 1.8 and everything works fine now.
                Thanks MrKen for your help, and thanks elvar for your post.
