Login or Sign Up
Logging in...
Remember me
Log in
Or
Sign Up
Forgot password or user name?
Log in with
Search in titles only
Search in Zabbix Help only
Search
Advanced Search
Forums
New Topics
Today's Posts
Home
Forum
Zabbix Help
Starting agent on Linux
FAQ
REGISTER
Posts
Latest Activity
Photos
Page
of
1
Filter
Time
All Time
Today
Last Week
Last Month
Show
All
Discussions only
Photos only
Videos only
Links only
Polls only
Events only
Filtered by:
Previous
template
Next
vlam
Jun 2009
166
19-01-2010, 11:36
How can I fix this problem??
server:/etc/zabbix # /usr/sbin/zabbix_agentd start
Floating point exception
4 Zabbix Frontend Servers (Load balanced)
2 Zabbix App Servers (HA)
2 Zabbix Database Servers (HA)
18 Zabbix Proxy Servers (HA)
3897 Deployed Zabbix Agents
6161 Values per second
X-Layer Integration
Jaspersoft report Servers (HA)
Firm
Dec 2009
342
19-01-2010, 18:31
'strace /usr/sbin/zabbix_agentd' (without quotes) please
Post
Cancel
vlam
Jun 2009
166
20-01-2010, 07:57
Here is the strace output
metadad:/usr/sbin # /usr/bin/strace ./zabbix_agentd start
execve("./zabbix_agentd", ["./zabbix_agentd", "start"], [/* 59 vars */]) = 0
uname({sys="Linux", node="metadad", ...}) = 0
brk(0) = 0x806f000
open("/etc/ld.so.preload", O_RDONLY) = -1 ENOENT (No such file or directory)
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40017000
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=77599, ...}) = 0
old_mmap(NULL, 77599, PROT_READ, MAP_PRIVATE, 3, 0) = 0x40018000
close(3) = 0
open("/lib/tls/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p5 \0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=170563, ...}) = 0
old_mmap(NULL, 137712, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4002b000
madvise(0x4002b000, 137712, MADV_SEQUENTIAL|0x1) = 0
old_mmap(0x4004c000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x4004c000
close(3) = 0
open("/lib/libresolv.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`+ \0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=74342, ...}) = 0
old_mmap(NULL, 73588, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4004d000
madvise(0x4004d000, 73588, MADV_SEQUENTIAL|0x1) = 0
old_mmap(0x4005c000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xf000) = 0x4005c000
old_mmap(0x4005d000, 8052, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4005d000
close(3) = 0
open("/lib/tls/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@S \1\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=1345545, ...}) = 0
old_mmap(NULL, 1128748, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4005f000
madvise(0x4005f000, 1128748, MADV_SEQUENTIAL|0x1) = 0
old_mmap(0x40168000, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x109000) = 0x40168000
old_mmap(0x40170000, 10540, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40170000
close(3) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40173000
--- SIGFPE (Floating point exception) @ 0 (0) ---
+++ killed by SIGFPE +++
metadad:/usr/sbin #
X-Layer Integration
Post
Cancel
vlam
Jun 2009
166
20-01-2010, 08:46
Here is another floating point exception.
What can it be.
The OS is SuSE Enterprise Linux 10 SP1 64-bit
metsapgui:/etc/zabbix #
metsapgui:/etc/zabbix # cat /etc/passwd | grep zabbix
zabbix:x:1001:100::/home/zabbix:/bin/bash
metsapgui:/etc/zabbix # /usr/sbin/zabbix_agentd start
metsapgui:/etc/zabbix # /usr/bin/strace /usr/sbin/zabbix_agentd start
execve("/usr/sbin/zabbix_agentd", ["/usr/sbin/zabbix_agentd", "start"], [/* 59 vars */]) = 0
[ Process PID=13070 runs in 32 bit mode. ]
brk(0) = 0x806f000
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfffffffff7ee5000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
fstat64(0x3, 0xfffe024c) = 0
mmap2(NULL, 92680, PROT_READ, MAP_PRIVATE, 3, 0) = 0xfffffffff7ece000
close(3) = 0
open("/lib/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0 004\0"..., 512) = 512
fstat64(0x3, 0xfffe02e4) = 0
mmap2(NULL, 147584, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xfffffffff7ea9000
madvise(0xf7ea9000, 147584, MADV_SEQUENTIAL|0x1) = 0
mmap2(0xf7ecc000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x22) = 0xfffffffff7ecc000
close(3) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0P& \0\000"..., 512) = 512
fstat64(0x3, 0xfffe02c8) = 0
mmap2(NULL, 76052, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xfffffffff7e96000
madvise(0xf7e96000, 76052, MADV_SEQUENTIAL|0x1) = 0
mmap2(0xf7ea5000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe) = 0xfffffffff7ea5000
mmap2(0xf7ea7000, 6420, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xfffffffff7ea7000
close(3) = 0
open("/lib/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\3 00Y\1"..., 512) = 512
fstat64(0x3, 0xfffe02ac) = 0
mmap2(NULL, 1185180, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0xfffffffff7d74000
madvise(0xf7d74000, 1185180, MADV_SEQUENTIAL|0x1) = 0
mmap2(0xf7e8f000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11a) = 0xfffffffff7e8f000
mmap2(0xf7e93000, 9628, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xfffffffff7e93000
close(3) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xfffffffff7d73000
set_thread_area(0xfffe07b8) = 0
Process 13070 detached
X-Layer Integration
Post
Cancel
vmedek
Jul 2009
12
20-01-2010, 12:48
it is instalation from source?
try to use rpm from
http://download.opensuse.org/reposit...ing/SLE-10-SP1
then you can start it from /etc/init.d - I have no problems with it.
Post
Cancel
jamesh
Mar 2008
22
14-04-2010, 20:01
Getting the same problem with the 1.8 and 1.8.2 agent binaries for Linux 2.6 x64. Had to revert to a known-good 1.4.4 binary.
uname -a
Linux xxx 2.6.9-67.0.15.ELsmp #1 SMP Tue Apr 22 13:58:43 EDT 2008 x86_64 x86_64 x86_64 GNU/Linux
cat /etc/redhat-release
Red Hat Enterprise Linux AS release 4 (Nahant Update 3)
Nothing written to the debug log either. Strace looks the same as the one posted above.
Post
Cancel
Previous
template
Next
OK
OK
Cancel
