how to configure the web monitoring notification
  • zjdick
    • Jan 2010
    hello,all:
    i am using zabbix(Verssion:1.8) for the first time, and i want to monitor some web pages.
    i created the web monitoring scenarios,but the zabbix did't sent the notifications when the scenario is failed.
    i got some information from zabbix forum,which says i should create items and triggers first,and zabbix agent have some web items,like "web.test.fail"... but my zabbix only have three web item keys:
    web.page.get[host,<path>,<port>]
    web.page.perf[host,<path>,<port>]
    web.page.regexp[host,<path>,<port>,<regexp>,<length>]
    but,i didn't know how to use this,i want to monitor some urls,like " www.google.com",i need to get the response code,and the full response time,what can i do?
    If any body knows, Please help me.
    Thank you.
  • richlv
    • Oct 2005
    • 3112
    you can use automatically created items when a web scenario is created. for more information, see http://www.zabbix.com/documentation/...web_monitoring
    • fore
      • Jan 2010
      • 33
      He wrote that the scenario has already been created, and the item "web.test.fail" not appear...
      • richlv
        • Oct 2005
        • 3112
        he didn't refer to actual web scenario keys that are automatically created (those are not visible in item config section). unless there's some yet unknown bug, items most likely have been created, all that's left - trigger[s] must be created for those
