I get a banch of errors in the logs any idea what to do about it?
5748:20100121:175719.182 Item [Zabbix Server:kernel.maxproc] error: Not supported by Zabbix Agent
5745:20100121:175721.512 Item [Zabbix Server:net.if.in[eth1,bytes]] error: Not supported by Zabbix Agent
5748:20100121:175724.191 Item [Zabbix Server:net.if.out[eth1,bytes]] error: Not supported by Zabbix Agent
5746:20100121:175742.491 Item [Zabbix Server:sensor[temp1]] error: Not supported by Zabbix Agent
5747:20100121:175743.903 Item [Zabbix Server:sensor[temp2]] error: Not supported by Zabbix Agent
5748:20100121:175744.297 Item [Zabbix Server:sensor[temp3]] error: Not supported by Zabbix Agent
5747:20100121:175803.954 Item [Zabbix Server:vfs.file.cksum[/etc/inetd.conf]] error: Not supported by Zabbix Agent
5747:20100121:175809.966 Item [Zabbix Server:vfs.file.cksum[/vmlinuz]] error: Not supported by Zabbix Agent
5745:20100121:180106.825 Item [winxp-l1
erf_counter[\Physical Disk(_Total)\Avg. Disk Read Queue Length]] error: Not supported by Zabbix Agent
5747:20100121:180113.201 Item [winxp-l1
roc_cnt[httpd]] error: Not supported by Zabbix Agent
5746:20100121:180122.871 Item [winxp-l1:system.uptime] error: Not supported by Zabbix Agent
5747:20100121:180123.214 Item [winxp-l1:system[procrunning]] error: Not supported by Zabbix Agent
5748:20100121:180129.513 Item [winxp-l1:vfs.fs.size[d:,free]] error: Not supported by Zabbix Agent
5744:20100121:180130.622 Item [winxp-l1:vfs.fs.size[d:,total]] error: Not supported by Zabbix Agent
erf_counter[\Physical Disk(_Total)\Avg. Disk Read Queue Length]] error: Not supported by Zabbix Agent5747:20100121:180113.201 Item [winxp-l1
roc_cnt[httpd]] error: Not supported by Zabbix Agent5746:20100121:180122.871 Item [winxp-l1:system.uptime] error: Not supported by Zabbix Agent
