Is it possible to create a calculated item that would be the ratio of two other items?
It seems that all the pieces are there, it is possible to calculate a ratio in triggers, so Zabbix knows how to do that, and it also has the concept of aggregated items, which are calculated based on other items. However, when I tried creating a new aggregated item which is the ratio between two other aggregated items it didn't work. Any way to do that?
Thanks,
Eran
Thanks,
Eran
