zabbix 1.8 and postgresql 8.3.9
  • ufocek
    • Aug 2006
    • 161
    I have installed zabbix 1.8 with postgresql 8.3.9 and now size of zabbix db is 16G. It's a normal situation?
    Parameter	Value	Details
    Zabbix server is running	No	-
    Number of hosts (monitored/not monitored/templates)	100	54 / 3 / 43
    Number of items (monitored/disabled/not supported)	6021	4582 / 1409 / 30
    Number of triggers (enabled/disabled)[true/unknown/false]	2436	2393 / 43  [30 / 34 / 2329]
  • Firm
    • Dec 2009
    • 342
    It's normal. Check if you need to monitor all the items that are defined in templates you use. Moreover, it may be worth to increase 'Update interval' for some items.
