Where do I define what Community String Zabbix has to sue
  • jmj
    • Jan 2010
    I am running Zabbix 1.8.
    I have used "Creat Host" to monitor 2 of our switchs, with the Template_cisco_877 for one and Template_SNMPv2_Device.
    Can someone tell me where in zabbix I have to define the SNMP community string we use to access our switchs ( that is not 'public') .
    Is there a way to define a "Default community string" that will be used for all added host created with a dedicated group ?
  • jmj
    • Jan 2010
    Well, I've done it via
    mysql> update `items` set `snmp_community` = "xxxxxxx" WHERE `snmp_community` = "public" ;
    Query OK, 4197 rows affected (0.43 sec)
    Rows matched: 4197 Changed: 4197 Warnings: 0
    Is there another way ? (more "user-friendly").
    JM
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Of course there is a much better way - use mass-update for items.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • jmj
        • Jan 2010
        Hi Alexei,
        Thanks for this answer, but may I ask you to be a bit more explicite, I am quite new with zabbix, but do network monitoring since more than 10 years.
        regards,
        JMJ
        • jmj
          • Jan 2010
          OK, got it. I haven't seen the "Items" Column in the "Hosts" view...
          Thanks anyway.
          regards
          JMJ
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Sorry for being very brief in my previous response. I'll do better next time!
            Select all host items in the list of items and then select 'Mass update' option in the drop-down below the list.
            Alexei Vladishev
            My Twitter
