configuration-changes using Im/Export
  • janb
    • Aug 2008
    I´ve made a lot of configuration changes for one host and exported the configuration. I alter the XML file "changing Hostname" in every trigger and item and the hostname itself. I basically try to copy the whole configuration to another host.
    Then I import the altered xml-file. The result is, that all triggers are update, but the values for the trigger come from the host I used at first. Not from the new host, for which I have made the changes.
    Do I have a basic misunderstanding of how the Import/export works, or how I should use the condiguration, or is there a bug?
    I use Version 1.8.1
    Cheers
    Jan
