How to clear history of one trigger....
  • mafa
    • Jan 2010
    I created one trigger and tested it several times, before switch to production I would like to clear all historical data for this trigger (I would like to have a clear Availability report) before start production monitoring – how to do it?
  • madutis
    • Mar 2010
    Same question here.
    Thanks.
    • untergeek
      • Jun 2009
      • 512
      Even if this is a complicated SQL query I have to run manually, I'd like to know a way to do this also.
      • madutis
        • Mar 2010
        I have found a way to do this in SQL.
        DISCLAIMER: Use at your own risk, these are just guidelines, you will have to adjust values for your situation.
        Basically you need to erase all rows from service_alarms with serviceid that you need.
        You can look up serviceid's in table 'services'.
        delete from service_alarms where serviceid=2 and servicealarmid > 10;
        I have added 'servicealarmid > 10' as top rows contain '0' values for each service apparently for a calculation to be correct.
        Do this for a service and every parent IT service.
        Hope this helps,
        Darius
