zabbix_agentd.conf
  • christogouws
    • Nov 2009
    • 20
    zabbix_agentd.conf
    Hi there,
    I have a config file that I want to copy accross to multiple servers.
    would it be possible to do this in the zabbix_agentd.conf file
    Hostname=`hostname`
    which runs the hostname command?
  • zabbix_zen
    • Jul 2009
    • 426
    What about something like,
    HOST=`uname -n`
    ZBX_PATH=zabbix_cfg_files_path
    sed --in-place "s/Hostname=system.uname/Hostname=$HOST/g" $ZBX_PATH/zabbix_agentd.conf
    • christogouws
      • Nov 2009
      • 20
      Not exactly what I had in mind.
      I split all my UserParameters up into different files & want to deploy
      all the configs via SVN to a bunch of hosts.
      • trikke
        • Aug 2007
        • 140
        as far as i remember, commenting out the Hostname aka not defining it at all, forces the client to use `hostname`as name of the agent.
        Greets
        Patrick
        • christogouws
          • Nov 2009
          • 20
          Greets
          Patrick
          If that work's you are my hero.
          I'll give it a shot, thanx.
