how to create a trigger compares two string items?
  • sersad
    • May 2009
    • 518
    how to create a trigger compares two string items, to operate under the condition that they are different.
    There are two string values of the two an item.
    card10soft = "she-r23-iu_adsl72ifxa-o.743"
    card10softupg ="she-r23-iu_adsl72ifxa-o.746"
    You must write a trigger that would have worked in the case if these lines are not equal to each other.
    Reading the documentation it has
    ({{HOSTNAME}:card10softupg.last(0)}<{{HOSTNAME}:card10soft.last(0)})
    ({{HOSTNAME}:card10softupg.last(0)}>{{HOSTNAME}:card10soft.last(0)})
    or
    {{HOSTNAME}:card10softupg.last(0)}#{{HOSTNAME}:card10soft.last(0)}
    However, these triggers do not work. The status they have always known. The value of an item obtained without problems.
    Any solution?
  • sersad
    • May 2009
    • 518
    have any ideas?
