Hey guys,
is there actually a way to enable/disable ports (like procurve switch) via zabbix (to set ifAdminStatus) ?
I works with setsnmp...sure, but with zabbix frontend? I tried to use an own external script but it isn“t possible (with zabbix) to do some input in the internal popup window (like to choose an port and select the action).
Any suggestions?
Any suggestions?
