Zabbix item proc_info not supported in Linux?
  • yam
    • Feb 2010
    Using Zabbix (v1.8.1), I am trying to monitor the memory and CPU usage, among others, of a process. I need to achieve this in both Linux (RHEL 5U2/SLES 10SP2) and Win 2K3. I configured a Zabbix Server and installed agents in both my RedHat and Win Servers.
    There is an item called proc_info (proc_info[<process>,<attribute>,<type>]), which seems to fulfill my requirements. This has attributes like virtual memory, physical memory, page faults, kernel time, user time, etc. that we can monitor for a single process.
    However, what I see is, this item instantaneously becomes "Not Supported" in the status column for any Linux Agent, whereas it works fine for Windows. Is this feature not supported in Linux? Is there something I am missing? Or, is there a better way to achieve my requirements?
    zabbix_agentd --version
    ZABBIX Agent (daemon) v1.8.1 (revision 9702) (27 January 2010)
    Compilation time: Feb 11 2010 10:42:39
    zabbix_server --version
    Zabbix Server (daemon) v1.8.1 (revision 9702) (27 January 2010)
    Compilation time: Feb 9 2010 14:56:08
    Would appreciate any help/pointers.
    Thanks.
  • MrKen
    • Oct 2008
    • 652
    Hi yam,
    Yes, you are missing something - the link to the wiki. Section 4.19.3 Zabbix Agent, at the bottom of that section just before 4.19.4 (SNMP Agent).
    proc_info is a Win32-specific parameter.
    http://www.zabbix.com/documentation/1.8/manual/config/items#zabbix_agent
    MrKen
    • yam
      • Feb 2010
      Hi Mrken,
      Thanks for pointing that out.
      Is there a way I can achieve a similar objective in Linux as well, i.e., monitoring at the process level? I saw an item called proc.mem, but this only helps in getting the memory usage.
      Thanks.
      • MrKen
        • Oct 2008
        • 652
        Read through the list of items on that wiki page. But I'm only aware of proc.mem and proc.num.
        Maybe you might need to do it by snmp. (Not the answer you were looking for ).
        MrKen
        • yam
          • Feb 2010
          Could not get any other item in the list which could help in that.
          Thanks for your time.
