interval on incoming traffic on interface eth0
  • mattlf
    • Feb 2010
    Hi
    I am trying to increase the interval on monitored items so that the history table doesn't grow as much
    What would you recommend for the incoming traffic on interface eth0 ? Right now is it 5 seconds. Does 20 seconds make sense ?
    Thank you
  • nelsonab
    • Sep 2006
    • 1233
    I tend to set most of my items to a minimum granularity of 60 seconds. I find this works well and the graphs still look pretty good. If I *really* need granular data points I will use 30 seconds but nothing less.
    RHCE, author of zbxapi
