Data From External Script Not Updated on Server
  • js1
    • Apr 2009
    • 66
    I'm running an external script check on the the internet root dns servers. As shown in the screenshot, some are working, while others (f, i, j, and m) are not.
    The script is executed by various zabbix proxies. For the root server f specifically, the proxy assigned to check it is collecting the data:
     12015:20100218:124501 /var/lib/zabbix/externalscripts/getdnsresponsetime.sh f.root-servers.net
     12033:20100218:124501 Query [select httptestid,name,applicationid,nextcheck,status,delay,macros,agent from httptest where status=0 and nextcheck<=1266515101 and mod(httptestid,1)
    =0]
     12033:20100218:124501 End process_httptests()
     12033:20100218:124501 Spent 0 seconds while processing HTTP tests
     12033:20100218:124501 Query [select count(*),min(nextcheck) from httptest t where t.status=0 and mod(t.httptestid,1)=0]
     12033:20100218:124501 No httptests to process in get_minnextcheck.
     12033:20100218:124501 Nextcheck:-1 Time:1266515101
     12033:20100218:124501 Sleeping for 5 seconds
     12015:20100218:124501 Result [32]
     12015:20100218:124501 End get_value()
     12015:20100218:124501 Query [begin;]
     12015:20100218:124501 In proxy_process_new_value(getdnsresponsetime.sh[]) 12015:20100218:124501 In proxy_add_history(itemid:69301,key:"getdnsresponsetime.sh[]",value_type:0,DOUBLE:32.000000)
     12015:20100218:124501 In proxy_add_history()
     12015:20100218:124501 Query [insert into proxy_history (itemid,clock,value) values (69301,1266515101,'32.000000')]
     12015:20100218:124501 End of proxy_add_history
     12015:20100218:124501 In proxy_update_item()
     12015:20100218:124501 In calculate_item_nextcheck (69301,600,"",1266515101)
     12015:20100218:124501 End calculate_item_nextcheck (result:1266515701)
     12015:20100218:124501 Query [update items set nextcheck=1266515701 where itemid=69301]
     12015:20100218:124501 End proxy_update_item() 12015:20100218:124501 Query [commit;] 12015:20100218:124501 End get_values()
     12015:20100218:124501 Poller spent 0.251194 seconds while updating   1 values. Sleeping for 5 seconds
     12011:20100218:124502 In history_sender() 12011:20100218:124502 In get_history_data() [table:proxy_history]
     12011:20100218:124502 In get_lastid() [proxy_history.history_lastid]
     12011:20100218:124502 Query [select nextid from ids where table_name='proxy_history' and field_name='history_lastid']
     12011:20100218:124502 End of get_lastid() [proxy_history.history_lastid]:5620370
     12011:20100218:124502 Query [select p.id,h.host,i.key_,p.clock,p.timestamp,p.source,p.severity,p.value from hosts h,items i,proxy_history p where h.hostid=i.hostid and i.itemid=p
    .itemid and p.id>5620370 order by p.id limit 1000]
     12011:20100218:124502 In dhistory_sender()
     12011:20100218:124502 In get_dhistory_data() [table:proxy_dhistory] 12011:20100218:124502 In get_lastid() [proxy_dhistory.dhistory_lastid] 12011:20100218:124502 Query [select nextid from ids where table_name='proxy_dhistory' and field_name='dhistory_lastid'] 12011:20100218:124502 End of get_lastid() [proxy_dhistory.dhistory_lastid]:104 12011:20100218:124502 Query [select id,clock,druleid,type,ip,port,key_,value,status from proxy_dhistory where id>104 order by id limit 1000] 12011:20100218:124502 Datasender spent 0.017575 seconds while processing   0 values. 12011:20100218:124502 Sleeping for 1 seconds 12016:20100218:124502 In get_values() 12016:20100218:124502 Query [select i.itemid,i.key_,h.host,h.port,i.delay,i.description,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h.useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.hostid,h.status,i.value_type,h.errors_from,i.snmp_port,i.delta,i.prevorgvalue,i.lastclock,i.units,i.multiplier,i.snmpv3_securityname,i.snmpv3_securitylevel,i.snmpv3_authpassphrase,i.snmpv3_privpassphrase,i.formula,h.available,i.status,i.trapper_hosts,i.logtimefmt,i.valuemapid,i.delay_flex,h.dns,i.params,i.trends,h.useipmi,h.ipmi_port,h.ipmi_authtype,h.ipmi_privilege,h.ipmi_username,h.ipmi_password,i.ipmi_sensor,i.lastlogsize from hosts h, items i where i.nextcheck<=1266515107 and h.hostid=i.hostid and h.status=0 and i.status
    in (0,3) and ((h.disable_until<=1266515102 and h.errors_from=0 and i.type in (0,1,4,6)) or i.type in (3,5,8,10,11)) and (h.proxy_hostid=0 or i.type in (5,8)) and mod(i.itemid,5)=2 and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') order by i.nextcheck]
     12016:20100218:124502 End get_values()
     12016:20100218:124502 Poller spent 0.007593 seconds while updating   0 values. Sleeping for 5 seconds
     12011:20100218:124503 In history_sender()
     12011:20100218:124503 In get_history_data() [table:proxy_history]
     12011:20100218:124503 In get_lastid() [proxy_history.history_lastid]
     12011:20100218:124503 Query [select nextid from ids where table_name='proxy_history' and field_name='history_lastid']
     12011:20100218:124503 End of get_lastid() [proxy_history.history_lastid]:5620370
    The hosts were cloned from each other. Root servers i and j are monitored by the same proxy, while m is monitored by yet another. We use the exact same script and proxies to monitor our internal dns servers without issues. Why would some be working but others not? Please let me know if I need to supply more debugging information.
  • js1
    • Apr 2009
    • 66
    So, I turned up debug on a couple of my proxies: one that's updating and one that's not. It looks like on the one working/updating one, the proxy calls connect_to_server(), put_data_to_server(), send_data_to_server(), and recv_data_from_server(). Why would one proxy do this correctly while the other one does not?
     14650:20100305:172607 In connect_to_server() [zabbix-server]:10051 [timeout:600]
     14650:20100305:172607 In put_data_to_server() [datalen:186]
     14650:20100305:172607 In send_data_to_server() [{
            "request":"history data",
            "host":"working-proxy",
            "data":[
                            "host":"myhost",
                            "key":"mycheck.sh[]",
                            "clock":1267827966,
                            "value":"0"}],
            "clock":1267827967}]
     14650:20100305:172607 In recv_data_from_server()
     14650:20100305:172607 Received [{
            "response":"success",
            "info":"Processed 1 Failed 0 Total 1 Seconds spent 0.008731"}] from server
     14650:20100305:172607 End of put_data_to_server():SUCCEED
