SQL Query to find all triggers with status problem
  • AtomcMan
    • Feb 2010
    I require an SQL query to return the records in the zabbix database that show the triggers that are in a problem state. This is exactly the same as what is displayed in the 'Last 20 issues' on the dashboard page. I do not have any trigger dependencies setup so it shouldn't be as complex.
    The events tables seems to be the one to look at but it gives some false positives (equating to the records that have flashing 'OK' values)
  • mrogers-9898
    • Sep 2008
    • 68
    I've been messing with this myself...
    Its a bit all over the place, i'm sure with a bit of work it could be one query...
    I get a list of the HostIDs I wish to check for trigger status, then with that HostID I check for triggers with,
    select i.itemid, f.triggerid, t.description
    from items i
    left join hosts h on i.hostid = h.hostid
    left join functions f on i.itemid = f.itemid
    left join triggers t on f.triggerid = t.triggerid
    where h.hostid = *HostID*
    and t.status = 0
    and i.status = 0
    I then use the f.triggerid from that last query on
    Select priority
    from triggers
    where triggerid = *triggerid*
    and value <> 0
    I also check to see if its been acknowledged or not with the same triggerid (notice the query uses objectid not triggerid - strange)
    SELECT acknowledged
    FROM events e
    where objectid = *triggerid*
    order by clock desc
    limit 1
    That last query appears really dodgey to my eyes, but with myself having limited SQL-fu thats as far as I've gotten....
    • danrog
      • Sep 2009
      • 164
      This is what we use for a mobile version of the triggers page (includes last value for those triggers that have {ITEM.LASTVAUE} as part of the description.
      $query= 'SELECT DISTINCT host, t.description, f.triggerid, e.acknowledged, t.value, i.lastvalue '.
      ' FROM triggers t'.
      ' INNER JOIN functions f ON ( f.triggerid = t.triggerid )'.
      ' INNER JOIN items i ON ( i.itemid = f.itemid )'.
      ' INNER JOIN hosts ON ( i.hostid = hosts.hostid )'.
      ' INNER JOIN events e ON ( e.objectid = t.triggerid )'.
      ' WHERE (e.eventid DIV 100000000000000)'.
      ' IN (0)'.
      ' AND (e.object-0)=0'.
      ' AND (t.value=1 OR (t.value =0 AND unix_timestamp(now()) - t.lastchange <60))'.
      ' AND hosts.status =0'.
      ' AND i.status =0'.
      ' AND t.status =0'.
      ' GROUP BY f.triggerid'.
      ' ORDER BY t.lastchange DESC';
      • mrogers-9898
        • Sep 2008
        • 68
        nice query, danrog!
        I see your SQL-fu is strong.
        • AtomcMan
          • Feb 2010
          Thanks heaps for that It works nicely.
          I did find I needed to remove the line ' WHERE (e.eventid DIV 100000000000000)'. otherwise I got no results
          • danrog
            • Sep 2009
            • 164
            AtomcMan, out of curiosity, what type of DB are you using?
            • AtomcMan
              • Feb 2010
              We are using MySQL on CentOS 5.4
              • danrog
                • Sep 2009
                • 164
                Hmm....odd that "WHERE (e.eventid DIV 100000000000000)" didn't work for you. I use MySQL as well and all my custom queries use similar where conditions. Oh well, as long as the rest works for you.
                • mrogers-9898
                  • Sep 2008
                  • 68
                  How would you adjust the query to find only active triggers that have not been acknowledged?
                  • melpheos
                    • Dec 2008
                    • 64
                    AND e.acklowledged = 0
                    strangly enough it was working last week for me but it seems the change to summertime has screwed everything up and it's not working anymore :-/
                    Now i get same results with e.acknowledged = 0 and = 1...
                    Need to find what is wrong with the query
                    • mrogers-9898
                      • Sep 2008
                      • 68
                      thanks! that was pretty clear once you pointed it out
                      I appear to get consistent results with changing the e.acknowledged value to 0/1.
                      • exkg
                        • Mar 2007
                        • 718
                        Also is helpfull click in option debug (to right) in ZABBIX GUI ... is possible see all queries used in each page.
                        []s,
                        Luciano
                        Luciano Alves
                        www.zabbix.com
                        Brazil | México | Argentina | Colômbia | Chile
                        Zabbix Performance Tuning
                        • melpheos
                          • Dec 2008
                          • 64
                          i think my database has been somewhat corrupted by the summer time change because i can't get the result i had before
                          • melpheos
                            • Dec 2008
                            • 64
                            OK it was the database that was a bit broken after change to summertime with trigger activated.
                            After deleting the trigger and deleting the events directly in the DB it went back to normal.
                            As a bonus, here is a correction of the query
                            put
                            AND e.object=0
                            instead of (e.object-0)=0 (which does nothing at all but at a useless calculation)
                            The query takes .03 seconds instead of......... damn that's long seconds...
                            Edit : still a small problem. When a trigger is active and has been acknowledged but the same trigger has been active in the past but resolved and was not acknowledged, you still receive results with this query. You can either make an acknowledge on the whole db from time to time or we need to find another query. Working on it and keep you posted
                            • melpheos
                              • Dec 2008
                              • 64
                              #15
                              Finally after some more work i got what i need
                              SELECT DISTINCT host, f.triggerid, e.acknowledged, priority
                              FROM triggers t
                              IN (0)
                              AND e.object = 0
                              AND t.value=1
                              AND hosts.status = 0
                              AND i.status = 0
                              AND t.status = 0
                              AND e.acknowledged = 0
                              AND e.clock > (SELECT DISTINCT max(e.clock)
                              FROM triggers t
                              IN (0)
                              AND e.object = 0
                              AND t.value=1
                              AND i.status = 0
                              AND t.status = 0
                              AND e.acknowledged = 1
                              ORDER BY priority DESC;
