Install problem
  • hsoussou
    • Mar 2010
    • 21
    Install problem
    Hello
    When i tape make install, i have this :
    Making install in zbxcrypto
    make[2]: Entering directory `/root/Desktop/zabbix-1.8.1/src/libs/zbxcrypto'
    make[3]: Entering directory `/root/Desktop/zabbix-1.8.1/src/libs/zbxcrypto'
    make[3]: Nothing to be done for `install-exec-am'.
    make[3]: Nothing to be done for `install-data-am'.
    make[3]: Leaving directory `/root/Desktop/zabbix-1.8.1/src/libs/zbxcrypto'
    make[2]: Leaving directory `/root/Desktop/zabbix-1.8.1/src/libs/zbxcrypto'
    ..etc, etc
    Can you explain me where is the problem, thank you
  • tchjts1
    • May 2008
    • 1605
    That's not necessarily an issue. I get those same make entries when I compile... doesn't affect anything. Are you doing sudo make install?
    • hsoussou
      • Mar 2010
      • 21
      Yes i did sudo
      but i don't find /etc/zabbix/zabbix_server.conf , the folder "zabbix" dosn't exist in "etc"
      shall i create it ?
      • hsoussou
        • Mar 2010
        • 21
        Yes, it installed, and i must create the folder
        thank you
