Hello!
After installing the latest version of Zabbix (1.8.1), one problem showed up. While making maps, I can't add any of Windows agent (example - HP Insight Tools..) and few Zabbix agent triggers on it.
I can add an element on map, after clicking on it, "Edit Map Element" window shows up, and, after choosing Trigger as element type, and clicking on "Select", "Triggers" windows pops-up. I can see all the triggers, but, none can be selected. It's like that On-Click function doesn't work (I checked page source for Windows agent triggers (which can not be selected!) and for Zabbix agent trigger (which can be selected), and there weren't any problems..).
Could it be some bug in installation, or there could be other poblems?
