Hello
I have just installed the zabbix server and it seamed pretty easy to do it following the documentation.
At the moment i am using nagios to monitor my clients network, but there are so many thing to configure in nagios for everything that i started to look for other (better solutions).
With nagios it was pretty easy, i read a book and all was crystal clear, but at the moment after looking through the documentation about zabbix i am totally confused. I have no clue how exactly is it working: the zabbix server queries the agent? Or the agent sends informations to the server? If the client is sending how will the server be notified if the client is down for example?
Another thing: how can i monitor a simple station? I have installed as a service the agent on a windows workstation but i see nothing? I only see it in the dashboard as active and that is it...i went to items and services and enabled alot of checks on it but i see no alerts, no nothing?
Do i have to configure the triggers on the workstation or the server will send certaint queries (linke nagios + nsclient or nrpe ) ?
I am sorry but the documentation is really confusing and scarce.
How cand i use the descovery feature? i configures the subnet, type agent, but nothing was found, i ended up adding the host mannually.
Is there a simple how to in which i can see a simple config between an agent and a server? So i can start from there cause at the moment my zabbix server is just a pretty interface with nothing usefull.
If anyone can shed some light into zabbix please let me know
