Trigger expression question
  • messiah
    • Oct 2008
    • 9
    I've stuck on one problem and can't find any solution via search, so...
    I wrote this expression in trigger:
    {host:system.swap.size[,used].last(0)}>{host:vm.memory.size[total].last(0)}*0.05
    But I get this error in server log:
    Expression [{13794}>{13793}*0.05] for item [23635][host:system.swap.size[,used]] cannot be evaluated: unable to get function value: lastvalue IS NULL for function [13793][host:vm.memory.size[total].last(0)]
    Is it possible to somehow write this expression correctly or it is not possible at all? I don't understand why it doesn't work. I've tried some other variations, but no luck.
  • richlv
    • Oct 2005
    • 3112
    item "host:vm.memory.size[total]" has not returned any data since you modified/created the trigger. make/wait for it to do so, and it should work
    • messiah
      • Oct 2008
      • 9
      Thanks a lot for your answer. Seems to be working!
