monitor specific URL's
  • mary nancy
    • Jul 2005
    • 125
    Hi
    I am using zabbix 1.1beta2 version . I would like to know what is the parameter used to monitor specific urls like http://www.alphacreations.com.
    Thanks and regards
    Nancy
  • elkor
    • Jul 2005
    • 299
    you could use check_service[], check_port[], or check_service_perf[] as described in the manual. or you could do a custom script.
    I don't know (because I haven't tried yet) if the built in functions will take a name vs ip address. If they don't, they probably should, that will have to be added as a feature request though; and you can always use an ip to get yourself running in the meantime.
