how can I get the latestdata from my DB
  • woody1112
    • Mar 2010
    hello everyone!
    I am a new to zabbix, and I have install it successfully on CentOS 5.4. The agent and server is on the same machine for test. I can see the graph in the web front-end, but the lastvalue in my DB(mysql) is always null or only a single number. Is my configuration not proper or there's some way to solve this issue? I want the historic data.
    Can anybody tell me how to tackle this, thanks a lot!!!! (:-))
  • bobrivers
    • Feb 2007
    • 115
    Sorry, but I didn't understood your problem. When you go to Monitoring > Latest Data, can you see something? Or do you want to access the database directly and see the values directly on the table?
    Are zabbix_server and zabbix_agentd started?
    Did you checked the zabbix log files in order to see if it throws any error message?
    Bob
    • woody1112
      • Mar 2010
      I have figured it out
      I thought that the data monitered is stored in DB one by one, but I only can find one single data in the table 'items'. Now I think that i can compose a program to get the data using this sentance: zabbix_get.
      thanks anyway!!
