I am a Zabbix newbie. I've looked through the forums but can't find anything explicitly on how to monitor and trigger based on the results of a process being found in a 'ps' response on the server with zabbix_agentd running.
Closest I found was: proc.num[<name>,<user>,<state>]
Is this the correct way to do this task?
Can someone give me an example on how to set up a monitor for say checking if process XYZ is running in a 'ps' listing and then triggering if it isn't found?
Thank you!
Thank you!
