event generation only after n consecutive failures
  • djoslin
    • Mar 2010
    I have looked all over for reference to this but have found nothing.
    I have a couple of services that I monitor that will pretty regularly fail a test and then come back on the next check. I would like to be able to configure the trigger so that n failures are required for event generation.
    Any ideas?
  • alixen
    • Apr 2006
    • 474
    Any ideas?
    We use this:
    {host:icmpping. max( #4 ) }<1
    to raise an alert only if ping fails 4 times.
    You can check http://www.zabbix.com/documentation/...onfig/triggers for more details on trigger functions.
    Hope this helps
    Alixen
    http://www.alixen.fr/zabbix.html
    • djoslin
      • Mar 2010
      That's it! Thanks you so much.
      I looked at the docs for that and it still does not speak to me of what I was looking for. Perhaps and example on that page that describes it more plainly?
      Thanks again,
      David
