Advanced trigger availability report
  • zetho
    • Jul 2009
    • 9
    Generally trigger reports are generated per daily/percentage basis in the It services section.
    Is there any possiblity to monitor complicated triggers (that are not monitorable with "show triggers" on item graph) in more detailed manner ? I mean that I would like to achieve a trigger graph very similiar to item graph .
    Thank You
  • zetho
    • Jul 2009
    • 9
    Actually I will answer myself
    It can be done with "calculated item" (see doc)
    regards
    • danrog
      • Sep 2009
      • 164
      I'd be curious to see this. Do you have an example of this calculated item?
      • zetho
        • Jul 2009
        • 9
        Sure,
        This is the item :
        last("apache-ap-01:web.test.fail[Query ap01]") / (last("apache-ap-01:web.test.fail[Ap-01 balancer2 status check]")+last("a[apache-ap-01:web.test.fail[Ap-01 balancer1 status check]")+1)
        It works like this . Normally Query ap01 returns 0 and balancer1 and balancer2 query returns 1 . This item is easily triggered with following trigger (item values chart is on the bottom ) :
        (({apache-ap-01:web.test.fail[Query
        ap01].last(0)})/({apache-ap-01:web.test.fail[Ap-01 balancer1 status
        check].last(0)}+{apache-ap-01:web.test.fail[Ap-01 balancer2 status
        check].last(0)}+1)#0)&(({apache-ap-01:web.test.fail[Query
        check].last(0)}+1)#1)
        Item values chart :
        apache balancer 1 balancer 2 Trigger final value
        0 1 1 = 0 -> OK
        0 1 0 = 0 -> OK
        0 0 0 = 0 -> OK
        1 1 1 = 1/3 -> Error
        1 1 0 = 1/2 -> Error
        1 0 0 = 1 -> Ok
        so the above trigger triggers only when final calculated value is not equal 1 or 0 . Formula for calculation is following :
        (Apache value ) / (balancer_1_value + balancer_2_value +
        1 )
        This '1' is used for purpose to avoid dividing by zero.
        regards
