gnokii sms
  • firque
    • Jun 2008
    • 32
    gnokii sms
    hi all
    i am need gnokii (or any other piece of software) to send sms to multiple users at the same time. i have been trying for hours now and i can only send it to one user.
    any ideas?
    i need to use the serial gsm modem we bought. sms services on the internet are no option :-)
    thanks for the help
    greets
  • rons4
    • Jan 2020
    • 15
    You also might want to check out SIGNL4 (https://www.signl4.com/) that can send Push, SMS and voice calls. It is available as a media type in Zabbix and also supports two-way communication, i.e. acknowledgements and annotations are send back into Zabbix.
    • Africala
      • Apr 2026
      What you’re facing is quite common when using a single GSM modem with tools like Gnokii. A single modem can usually send only one SMS at a time, so if you try to send to multiple users simultaneously, it ends up queuing them rather than sending in parallel.
      A few things you can try:
      • Use a queue-based approach where messages are sent sequentially but managed efficiently (Gnokii can handle this with scripts).
      • Increase throughput by using multiple GSM modems (each modem handles its own queue).
      • Check modem settings like SMS mode (PDU/Text) and ensure no delays are configured between sends.
      • Consider tools like Kannel or Gammu, which are better suited for handling bulk messaging with modems.
      Keep in mind that with a single serial modem, there’s always going to be a hardware limitation on speed. True parallel sending usually requires either multiple modems or a gateway setup.
      Hope that helps
