Zabbix migration 1.6 -> 1.8
  • zapienl
    • Apr 2009
    Hi all ,
    I'm trying to upgrade my zabbix database from 1.6 to 1.8, right now my problem is the data base migration. Zabbix documentation explains that I need yo execute an script in order to convert the database to UTF-8.
    When I execute the <upgrade> script, I got the following error :
    Acces denied for user 'root'@'localhost' (using password: NO)
    Any idea??? ... do I need to modify something in the <upgrade> script ???
    Regards
    Jedi knight,
    Leonel
  • exkg
    • Mar 2007
    • 718
    You need pas the same credencials to mysql client:
    ./upgrade -uroot -p <SOME PASS> zabbix
    []s,
    Luciano
    Luciano Alves
    www.zabbix.com
    Brazil | México | Argentina | Colômbia | Chile
    Zabbix Performance Tuning
    • zapienl
      • Apr 2009
      thanks a lot Luciano, I really appreciate it
      I'm going to try it as soon as possible. I'm sure it will work this way.
      Regards,
