Favicon?
  • CeeEss
    • Nov 2007
    • 103
    Favicon?
    Hi
    I can't get Chrome or IE to show my custom favicon, but in Firefox it shows briefly after login, then reverts to the red Z favicon. CSS maybe?
    tia
  • MrKen
    • Oct 2008
    • 652
    Not sure about Chrome of IE, but on FF you should be able to see it (permanently) after clearing the cache. [Tools -> Clear recent history -> check the Details tab].
    HTH
    • Jun.Liu
      • Apr 2007
      • 91
      just wondering how to change the favicon, could you please give me a hint?
      thanks!
      • boogi
        • Mar 2010
        Viewing page source (i.e. Ctrl+U on Firefox) of Zabbix site you will see:
        <link rel="shortcut icon" href="images/general/zabbix.ico" />
        Just replace file "zabbix.ico" with what you want. You may also want to read http://en.wikipedia.org/wiki/Favicon
        • CeeEss
          • Nov 2007
          • 103
          Yes, that's got it. page_header.php is the file to edit. i just replaced all references to images/general/zabbix in the "if($css) routine with my own thing.ico and after a little bullying of the caches, it's taken in all browsers. Zabbix changes frontend files frequently during development and it's still tricky to re-establish branding after a frontend upgrade but i'm getting better at it. This one goes on my fairly long list of things to edit after a frontend upgrade.
          thanks!
          - cal
          • Jun.Liu
            • Apr 2007
            • 91
            yes. I had did so and then search 'zabbix.ico' in all *.php file but fail to find it.
            Now I know it's defined in the page_header.php... thanks your information!
