How to separate data of the same type but from different sources
  • jader.dias
    • Mar 2010
    • 13
    I have a machine that receives data from multiple sources. This machine forwards the data to the Zabbix Trapper.
    I want to be able to view this data separately. One way of doing that is to send data from each source with a different fake hostname. But this is not ideal.
    I can receive this data in more than one host. I would like to be able to see data from source 1 on host A separately from source 2 on host A and from source 1 in host B.
  • richlv
    • Oct 2005
    • 3112
    so what's wrong with sending the data to different hosts and different items ?
    • jader.dias
      • Mar 2010
      • 13
      @richlv
      I am currently doing this manually. I send:
      datatypeA[source1]
      datatypeA[source2]
      I create a item per source. All the data shows separately in the host latest data. But what if I wanted to add a third source? I would have to create a third item manually, right? How to automatize this?
      • richlv
        • Oct 2005
        • 3112
        yes, adding new items isn't as easy. while that could be achieved by curl-scraping web frontend, better solution might be through the api - nelsonab was talking about getting trapper item adding for zabcon, i believe
        • nelsonab
          • Sep 2006
          • 1233
          Trapper has been added as an item type.
          RHCE, author of zbxapi
