Hello All,
My situation as follows:
- Ubuntu x64 server 9.10
- Server and Agent 1.8.2, compiled from source
- Agent is configured as Active and is not listening on any ports (confirmed with netstat)
- In the server i have cloned the Linux template and updated the "Type" to "Agent (Active)" and have assigned the host.
- Communication is working as expected and triggers are working
The following simulation fails:
If i stop the agent, values are not flowing to the server -- expected
Some triggers are changing to unknown, as there is no data -- understandable, and expected
The problem: No triggers are changing to PROBLEM, so i am not aware the host went down.
What i am trying to do:
Say the agent is running behind a firewall. The firewall is pingable, but the server at wich the agent is running is locking up, crashing, whatever. The Agent is in any case not reporting data. I want to create a trigger that catches this event.
What i've tried:
- Create a trigger wich looks at the item agent.ping. The problem is that every calculation is always resulting 1, as that is the last received value. What i wanted to do was see how long ago that last value was received. For example: Trigger if the last received value is older that 2 minutes ago.
- Searched forums
- tried may other combinations of triggers/functions
Anyone any idea how to do that?
What i've tried:
- Searched forums
