Dashboard and latest data
  • pinger
    • Jan 2010
    I would like to add a column to the "Last 20 Issues" dashboard where it displays the latest data collected for that alert. Instead of just seeing the alert severity, I'd also like to see the data that triggered the alert on the same screen. Something else that would be useful would be to directly link the alert to a graph of the item being monitored, instead of just being a pop-up window of the history of alerts. I think that from an operations point of view, knowing how long it's happened before isn't as important as seeing what's happening *now*. Zabbix has reports, leave that data there .
    Has anybody made a custom dashboard php that would allow this data to be displayed?
  • zabbix_zen
    • Jul 2009
    • 426
    You can kind of mimmic this by using the Macro {ITEM.LASTVALUE}
    in the Trigger name, it will translate to the Trigger's 1st item most recent value.
    Clicking in the issue's 'Last Change' timestamp will bring you to that Trigger's historic Events.
    I do agree that the Trigger expression shown on that window would get more useful if clicking in a specific item
    would jump to its graph rather than the default "show this item's current configuration"
