How to use Select filter
  • Scheffie
    • Apr 2005
    • 15
    L.S.
    Does anyone use how to use the select filter on the trigger monitoring page?
    How should a select query look like?
    tnx for helping!
    Bart
  • richlv
    • Oct 2005
    • 3112
    do you mean the filter at monitoring -> triggers ? that's just text search against trigger expressions, nothing too fancy
