Multiple
  • davalente
    • Apr 2010
    Multiple
    I have a host with multiple services of the same type (ex: database, apache, etc), that i want to monitor with zabbix_sender without copying the keys, i want something more dynamic.
    Imagine you have 2 instances of mysql in the same server, how can you create a template that fits into that reality.
    I don't want to create two keys for each metric, for exemple: mysql.ping[instance_1], mysql.ping[instance_2]... if i create mysql instance_3, i must go and configure it on the gui.
    Exemple:
    Host "XPTO", monitoring Mysql, something like:
    XPTO MySQL (4 Items)
    MySQL version
    MySQL uptime
    MySQL number of threads
    MySQL is alive
    How can i monitor another Mysql instance in the same host?
    When i use zabbix_sender with the key "mysql.ping" it updates the two instances.
    Can anyone help?!
    Best Regards
