Zabbix DB: triggers.value/priority question
  • rheoled
    • Mar 2010
    Hi, all.
    I have a Zabbix 1.4 mysql installation. I ran the following SQL query:
    select from_unixtime(lastchange), triggerid, value, status, priority, description from triggers
    where triggerid = 19138;
    I got the following result:
    from_unixtime(lastchange) triggerid value status priority description
    2010-04-15 14:02:21 19138 0 0 4 DISK / 1
    Question: How can a trigger have a value of 0 (false/untriggered) with a priority of 4 (error)? What does that mean?
    Thanks.
    Ed
  • rheoled
    • Mar 2010
    Anybody know if there is any 1.4 schema documentation? Specifically, the precise meanings of the various codes and how they work together?
    Just trying to figure out if triggers.priority is to be ignored if triggers.value = 0/false...
    • zabbix_zen
      • Jul 2009
      • 426
      the triggers.priority means the Trigger defined Severity.
      So of those possible 0,1,2,3,4,5 your query returns actually mean,
      Not Classified, Information, Warning, Average, High, Disaster
      BTW: You should really consider upgrading..
      • rheoled
        • Mar 2010
        If triggers.value = 0 (false/untriggered), should a triggers.priority value of 4 (error) or 5 (disaster) be ignored??
        In other words, does triggers.priority have any meaning when triggers.value = 0?
        • zabbix_zen
          • Jul 2009
          • 426
          I take it you're asking when the Trigger is inactive if you have to be concerned about it......
          No..
          Exactly the same when triggers.value = 1,
          that you configured that specific Trigger with that given priority/severity
          • rheoled
            • Mar 2010
            Ah, so the priority is set by configuration of a trigger, not by the result of a functional test. OK, that helps clear my confusion. Thanks.
