My Aim is to monitor Web Servers Running Jboss Instants started by individual users.
What I need with Zabbix:-
I add Server A and B to the default Linux Template
I create 2 templates as Template_web-00 and Template_web-01
Now I need to achieve this,
How can I achieve the above requirements?
- Server A:-User web-00 start jboss instant
Zabbix will monitor:-
http_port 8080 (tcp)
jnp_port 1099 (tcp)
JVM Threads and memory
- Server A:-User web-01 start jboss instant
http_port 8180 (tcp)
jnp_port 1199 (tcp)
- Server B:-User web-00 start jboss instant
jnp_port 1099 (tcp)
- Server B:-User web-01 start jboss instant
jnp_port 1199 (tcp)
- Server A and B:-Zabbix will monitor:-
CPU, Disk, memory etc...
- Items in Template_web-00:-Monitor tcp http port 8080
Monitor tcp jnp port 1099
Monitor JVM Threads and memory
Monitory uptime of this instant - Items in Template_web-01:-Monitor tcp http port 8180
Monitor tcp jnp port 1199
Monitor uptime of this instant
- Achievement-A (Groups and Individual items to monitor)I create 2 groups as web-00 and web-01
- Group Web-00:-This group should monitor items from Template_web-00 for Server A and B and nothing else.
- Group Web-01:-This group should monitor items from Template_web-01 for Server A and B and nothing else.
- I also need to monitory the status of Server A and B individually (eg: disk, cpu, memory etc..) without adding this servers to Group web-00 or web-01. If required may be added to a different group.
- Achievement-B (Maintains)
- IF I add Group web-00 for maintains It should not monitor the items only from Template_web-00 listed under this group for Server A and B. This should not stop the monitoring of items listed under group web-01 and also should not stop monitoring of disk, cpu, memory etc.. of Server A and B
- IF I add Group web-01 for maintains It should not monitor the items only from Template_web-01 listed under this group for Server A and B. This should not stop the monitoring of items listed under group web-00 and also should not stop monitoring of disk, cpu, memory etc.. of Server A and B
- If I add Server A for maintains It should not monitor any group, template and Individual items added to this server but monitoring of other Server B should be continued.
- Group Web-00:-
