Hi All,
I have created a web URL monitoring scenario, this url connect to 4 front-end sever through load balancer
Trigger A = "G9 - Public System not reachable" (Depends on :G9 Front-end Servers)
Trigger B = "G9 Front-end Servers"
Each server is dependent on 2 tcp ports, if either 1 of the tcp port is down then the server should be declared as not reachable
Trigger "G9 Front-end Servers" is as below.
({web2:net.tcp.port[localhost,1099].last(0)}=0 | {web2:net.tcp.port[10.4.122.2,8080].last(0)}=0) & ({web3:net.tcp.port[localhost,1099].last(0)}=0 | {web3:net.tcp.port[10.4.122.3,8080].last(0)}=0) & ({web4:net.tcp.port[localhost,1099].last(0)}=0 | {web4:net.tcp.port[10.4.122.4,8080].last(0)}=0) & ({web5:net.tcp.port[localhost,1099].last(0)}=0 | {web5:net.tcp.port[10.4.122.5,8080].last(0)}=0)
My Question:-
Or Is there any other way to get it working?
My Question:-
Trigger A which is dependent on Trigger B will be fired if Trigger B is not fired. Am I rite?
