Notification and trigger dependencies
  • ufocek
    • Aug 2006
    • 161
    I have a sample connection:
    Zabbix -- R1 -- R2 -- R3 --R4
    zabbix - 192.168.111.250
    R1 - 192.168.111.253
    R2 - 192.168.111.254
    R3 - 192.168.111.10
    R4 - 192.168.111.9
    and now I would like set notification when some router is down, and I create some scenarion, which options is a better:
    1) scenario
    R1 is down when:
    {n1:net.tcp.port[192.168.111.253,22].max(60)}=0 & {n1:net.tcp.port[192.168.111.254,22].max(60)}=0 & {n1:net.tcp.port[192.168.111.10,22].max(60)}=0 & {n1:net.tcp.port[192.168.111.9,22].max(60)}=0
    R2 is down when:
    R1 have status 1 and other routers have status 0
    R3 is down when:
    R1 have status 1 and router R2 have too status 1 other routers have status 0
    2) scenario
    if I create a trigger dependencies
    trigger R4 is down depends on trigger R3 is down, I get a message that the R4 is unreachable?
    trigger R3 is down depends on trigger R2 is down, I get a message that the R3 is unreachable?
    trigger R2 is down depends on trigger R2 is down, I get a message that the R1 is unreachable?
    And what happens if fall just a router R4 or R1?
