trouble supermicro IPMI
  • andre2008
    • Apr 2010
    • 17
    I have trouble with an supermicro system with iPMI Ver. 2.0.
    I can 't read with zabbix IPMI not read the sensor for Intrusion detection. All other sensors (Fan's and System Temp works fine) by Intrusion say Zabbix not supported.
    Trap is for me not an option for Intrusion sensor !!
    Can anybody help me?
    Intrusion | 0.000 | unspecified | ok | na | na | na | na | na | na
    PS Status | 0.000 | unspecified | ok | na | na | na | na | na | na
    IPMI in zabbix look on the first value - also 0.000 but i need the third value "ok". have anybody any idea how can
    tell zabbix to look via IPMI at the third value?
  • rocksteady
    • Apr 2010
    • 26
    I had same problem !!
    explaned Here
