problem with item with ssh agent
  • jgironda
    • Apr 2010
    • 14
    I had created a item for check Memory size, with the following data:
    Description: Memory
    Type SSH Agent
    Key ssh.run[memoria]
    Authentication method Password
    User name xxx
    Password xxx
    Executed script LANG= free | grep Mem | awk "{print $3 * 100 / $2}"
    Type of information Numeric(Float)
    Units %
    Use multiplier
    Update interval (in sec) 30
    The problem is that the item does not work in all host, in one host the result it is correct and the other host the "lastest data" is not updated.
    Why??
    In the host with the problem, I can execute the scritp and work fine.
    I would like know how Zabbix execute the script, for example:
    ssh user@ip 'LANG= free | grep Mem | awk "{print $3 * 100 / $2}"'
    Thank you for your time.
  • jgironda
    • Apr 2010
    • 14
    Nobody has this problem??????
    • bashman
      • Dec 2009
      • 432
      Have you tried to write ip and port?
      ssh.run[<unique short description>,<ip>,<port>,<encoding>]
      978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
      • alixen
        • Apr 2006
        • 474
        Are you sure that your command is working ?
        On Debian Lenny, I get:
        # LANG= free | grep Mem | awk "{print $3 * 100 / $2}"
        awk: line 1: syntax error at or near *
        If I replace double quotes by single quotes, it works:
        # LANG= free | grep Mem | awk '{print $3 * 100 / $2}'
        93.8524
        Regards,
        Alixen
        http://www.alixen.fr/zabbix.html
        • bashman
          • Dec 2009
          • 432
          On RedHat 5:
          awk: {print  * 100 / }
          awk:         ^ syntax error
          54.5354
          The same problem, try to change double quotes for simple quotes.
          • jgironda
            • Apr 2010
            • 14
            I do not try this becouse I had defined my item in a template, and I think that I can not put one ip.
            Thank you.
            • bashman
              • Dec 2009
              • 432
              Thank you.
              Ok, you can use macros when you're using templates.
              • jgironda
                • Apr 2010
                • 14
                93.8524
                Regards,
                Alixen
                The command no it is the problem, but thank very much you for the interest.
                I would like know as Zabbix Launch the scritp, for example:
                ssh user@host "command;command"
                • jgironda
                  • Apr 2010
                  • 14
                  I go to investigated using macros... I never user macros.
                  and do you now as Zabbix launch the command with ssh agent.
                  Thank you very much!!!
                  • alixen
                    • Apr 2006
                    • 474
                    I really think that it IS the problem since $ meta character is interpreted by the shell within double quotes, which is not the case with single quotes.
                    However, if you are convinced that bashman and myself are wrong, so be it ...
                    Zabbix uses libssh2 internally, so I think that it does not use ssh command.
                    Hope this helps
                    Alixen
                    • jgironda
                      • Apr 2010
                      • 14
                      Hope this helps
                      Alixen
                      Hello Alixen,
                      I are not convinced that you are wrong, I change the "" by '' 1000 time, and other change, but mi error es very stange:
                      I define the item (as up) but I change the "" by ''
                      I probe the script from zabbix server to monitoring server (4 server):
                      [root@smaxxxx01 html]# ssh operacion@smxxx20 LANG= free | grep Mem | awk '{print $3 * 100 / $2}'
                      Password:
                      96.4913
                      [root@smaxx01 html]# ssh operacion@smxxx24 LANG= free | grep Mem | awk '{print $3 * 100 / $2}'
                      Password:
                      98.0885
                      [root@smaxxx01 html]# ssh operacion@smxxx48 LANG= free | grep Mem | awk '{print $3 * 100 / $2}'
                      Password:
                      99.7297
                      [root@smaxxx01 html]# ssh operacion@smxxxx75 LANG= free | grep Mem | awk '{print $3 * 100 / $2}'
                      operacion@smxxx75's password:
                      96.4011
                      [root@smaxxxx01 html]# ssh operacion@smaxxx61 LANG= free | grep Mem | awk '{print $3 * 100 / $2}'
                      operacion@smxxx61's password:
                      85.8811
                      but in the last date, the host 48 show 0% evertime, and the 61, no show any result!!
                      Host image Description Last check down Last value Change History
                      20 image - other - (1 Items)
                      memoria 04 May 2010 14:51:47 96.58 % -0.01 % Graph
                      24 image - other - (1 Items)
                      memoria 04 May 2010 14:51:46 98.08 % +0.05 % Graph
                      48 image - other - (1 Items)
                      memoria 28 Apr 2010 13:04:15 0 % - Graph
                      75 image - other - (1 Items)
                      memoria 04 May 2010 14:51:47 96.32 % 0 % Graph
                      The correct value of smaxxx48 it is 99% and the smaxxx61 is 85%
                      • alixen
                        • Apr 2006
                        • 474
                        Hello Alixen,
                        Password:
                        96.4913
                        Your test is not valid, only 'free' command is run through ssh, remaining commands after first pipe are run locally on your zabbix server.
                        If you want to run all commands through ssh, you have to carefully quote them:
                        ssh operacion@smxxx20 "LANG= free | grep Mem | awk '{print $3 * 100 / $2}'"
                        Sorry to bother you with all these shell syntax details but if you want to check your commands, you have to be sure that they are run remotely.
                        Hope this helps
                        Alixen
                        • jgironda
                          • Apr 2010
                          • 14
                          Ok.... my mistake
                          I had checked with your command:
                          [root@smxxxx01 ~]# ssh operacion@smaxxx48 "LANG= free | grep Mem | awk '{print \$3 * 100 / \$2}'"
                          Password:
                          99,7495
                          [root@sxxxx01 ~]# ssh operacion@smaxxxx24 "LANG= free | grep Mem | awk '{print \$3 * 100 / \$2}'"
                          Password:
                          99.5417
                          [root@smaxxxx01 ~]# ssh operacion@smadxxx75 "LANG= free | grep Mem | awk '{print \$3 * 100 / \$2}'"
                          operacion@smadava75's password:
                          96.3551
                          And the check by ssh it is correct, but in zabbix not work fine.
                          I do not know that put in "Excecuted script" field in the Item.
                          Now, I write this:
                          And the Lastes date is not updated....
                          And In the zabbix logs, I do not see error...
                          23539:20100504:173346.813 Get value from agent result: '239265727'
                          23539:20100504:173346.813 End of get_value():SUCCEED
                          23539:20100504:173346.813 In calculate_item_nextcheck (18441,5,"",1272987226)
                          23539:20100504:173346.813 End calculate_item_nextcheck (result:1272987231)
                          23539:20100504:173346.813 In substitute_simple_macros (data:'ssh.run[memoria,{IPADDRESS},22,UTF8]')
                          23539:20100504:173346.813 End substitute_simple_macros (result:'ssh.run[memoria,10.xx.xx.16,22,UTF8]')
                          23539:20100504:173346.813 In substitute_simple_macros (data:'operacion')
                          23539:20100504:173346.813 In substitute_simple_macros(data:NULL)
                          23539:20100504:173346.814 In substitute_simple_macros (data:'XXXX')
                          23539:20100504:173346.814 In substitute_simple_macros (data:'"LANG= free | grep Mem | awk '{print \$3 * 100 / \$2}'"')
                          23539:20100504:173346.814 End substitute_simple_macros (result:'"LANG= free | grep Mem | awk '{print \$3 * 100 / \$2}'"')
                          23539:20100504:173346.814 In get_value() key:'ssh.run[memoria,{IPADDRESS},22,UTF8]'
                          23539:20100504:173346.814 In ssh_run()
                          23539:20100504:173346.994 ssh_run() Supported authentication methods:'publickey,password,keyboard-interactive'
                          Thank for your help
                          • jgironda
                            • Apr 2010
                            • 14
                            The issue is solve
                            The problem was in the item result, the separator decimal was different, one host with "." and other with ","
                            for this, in the scripts I put this:
                            sed -e 's/,/./'
                            And now Zabbix obtain the value correctly, becouse zabbix in my case work with "." separator for numeric type.
                            In other scripts the problem was the number format, becouse the result of the script was in cientific format, for example:
                            8.76575e+11
                            for this, in the awk, I had changed the command print by printf, for add a format:
                            printf "%15.0f\n", SUM
                            Thank you
                            • jangel
                              • Apr 2024
                              Hello, try using '' in the key ssh.run['memory']
