No active checks on server: host not found
  • uknet80
    • Apr 2010
    • 55
    Hi Guys,
    I am using save Linux machine as Zabbix server and agent, but still i get error host not found as shown bellow:
    server hostname is (test.linux.local), i have this record under DNS and /etc/hosts file, I can ping test.linux.local, linux.local, test and localhost too.
    zabbix_agentd.conf file configuration is
    Server=127.0.0.1
    Hostname=test.linux.local
    LogFile=/tmp/zabbix_agentd.log
    zabbix_server.log
    Sending list of active checks to [127.0.0.1] failed: host [test.linux.local] not found
    zabbix_agentd.log
    No active checks on server: host [test.linux.local] not found
    netstat -tupln
    tcp 0 0 0.0.0.0:10050 0.0.0.0:* LISTEN 4232/zabbix_agentd
    tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN 4185/zabbix_server
    any idea how to solve this?
    thanks
  • bashman
    • Dec 2009
    • 432
    Have you tried to write server IP instead of 127.0.0.1?
    Do you specify server port?
    978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
    • uknet80
      • Apr 2010
      • 55
      I have even specified server IP, still same thing. do i have to mention Hostname, I haven't specify server port, what do i need to add?
      Server=192.168.1.110
      • bashman
        • Dec 2009
        • 432
        You have to specify the Server IP and if you don't specify the port, 10050 will be the default port.
        http://www.zabbix.com/documentation/.../zabbix_agentd
        • uknet80
          • Apr 2010
          • 55
          how about adding new host, I have added new host and i am not getting errors. from web browser -> configuration -> Hosts, I have added the host, and it is monitored, but under Availability column, the Z mark is gray, it looks like the server can't see it agent. is that true or I am missing something?
          • bashman
            • Dec 2009
            • 432
            Yeah, that's right, when the Z mark is green means that the server can see the agent and they can communicate.
            • MrKen
              • Oct 2008
              • 652
              Don't confuse DNS name with Zabbix Hostname.
              Your test.linux.local looks like a dns name. DNS names should resolve with the IP address, however the Hostname in the zabbix_agentd.conf and in the GUI does not need to resolve anything, only itself.
              Try this:
              Hostname=uknet80Server
              Then in the gui, host config be sure you have the same Hostname and that you have selected 'Connect to: IP Address'.
              If test.linux.local is a resolvable dns name, you could do this:
              Server=test.linux.local
              And then be sure that you have selected 'Connect to: DNS Name' in the gui.
              MrKen
              • uknet80
                • Apr 2010
                • 55
                I restarted the server, and haven't start zabbix_server or agentd that is running on the same server. the strange think is till from the browser i can see the agent that is on the zabbix_server, and it is active.
                you said Hostname=uknet80Server, that is agent name or server name?
                • uknet80
                  • Apr 2010
                  • 55
                  Let me tell you my setting & Steps, I have been trying to fix this for three days with no luck:
                  Server IP address is 192.168.1.119 (test.linuxtest.localhost), i can ping the name from any where it is on DNS, the zabbix server act as server and agent, the following settings:
                  /etc/zabbix/zabbix_server.conf
                  ListenPort=10051
                  DBName=zabbix
                  DBUser=root
                  DBPassword=Password
                  /etc/zabbix/zabbix_agentd.conf
                  Server=192.168.1.119
                  Hostname=test.linuxtest.localhost
                  ListenPort=10050
                  machine 2 (Agent 2) has the following setting
                  /etc/zabbix/zabbix_agent.d.conf
                  Hostname=mv
                  ListenPort=10050
                  zabbix_server.log
                  4878:20100505:162204.796 Deleted 0 records from history and trends
                  4870:20100505:162458.422 Sending list of active checks to [192.168.1.119] failed: host [test.linuxtest.localhhost] not found
                  zabbix_agentd.log
                  4933:20100505:162458.419 zabbix_agentd active check started [192.168.1.119:10051]
                  4933:20100505:162458.422 No active checks on server: host [test.linuxtest.localhhost] not found
                  zabbix_agentd.loc on Agent2
                  2230:20100505:162817.174 zabbix_agentd collector started
                  2234:20100505:162817.183 No active checks on server: host [mv] not found
                  I will be so grateful if you could help me with this
                  • alixen
                    • Apr 2006
                    • 474
                    You have to make sure that server name in Zabbix server and agent are the same. See my remarks below.
                    ListenPort=10051
                    DBName=zabbix
                    DBUser=root
                    DBPassword=Password
                    According to screenshot this machine is called "Zabbix Server" not "test.linuxtest.localhost" in Zabbix.
                    ListenPort=10050
                    Hostname=mv
                    According to screenshot this machine is called vm not mv in Zabbix.
                    ListenPort=10050
                    zabbix_server.log
                    zabbix_agentd.log
                    Rename host "Zabbix Server" to "test.linuxtest.localhost" and replace "mv" by "vm" in zabbix agent configuration and it should be OK.
                    Regards,
                    Alixen
                    http://www.alixen.fr/zabbix.html
                    • uknet80
                      • Apr 2010
                      • 55
                      after changing the server name as you advised, I am not getting errors for the agent under the server test.linuxtest.localhost (192.168.1.119). THANKS FOR YOUR HELP
                      still I am getting error for machine 2 (Agent 2)
                      i have reinstalled the machine with a new name to prevent confution. Setting
                      Agent name (redhat2) 192.168.122.239
                      Hostname=redhat2
                      ListenPort=10050
                      server same "test.linuxtest.localhost (192.168.1.119)"
                      Error on server
                      13238:20100506:102935.455 Sending list of active checks to [192.168.122.239] failed: host [redhat2] not found
                      Error on Agent
                      11418:20100506:102732.513 No active checks on server: host [redhat2] not found
                      I can ping redhat2 from server side.
                      On the webmonitor host has been added: redhat2 with 192.168.122.239 (see image)
                      Do I need to add agent name into zabbix_server.conf file or any where else, because how can the server knows if a specific Agent authorised to send reports, is it only from the web browser (Configuration->Host->Create host)?
                      • MrKen
                        • Oct 2008
                        • 652
                        What happens if you link the Template_Linux to your Host redhat2?
                        [Shouldn't need to, but, maybe restart zabbix_agentd on redhat2]
                        MrKen
                        • uknet80
                          • Apr 2010
                          • 55
                          what do you mean by (What happens if you link the Template_Linux to your Host redhat2?) how can i do that?
                          • alixen
                            • Apr 2006
                            • 474
                            According to your snapshot, redhat2 host has 0 items, 0 triggers, 0 graphs. What do you expect ?
                            May be it is time to stop hacking Zabbix configuration, relax and read the manual: http://www.zabbix.com/documentation/1.8/manual
                            Regards,
                            Alixen
                            • uknet80
                              • Apr 2010
                              • 55
                              #15
                              the problem i have is the error message i am getting from the minute i start the service. active and passive check is disabled by default, do i need to enable them? do you have any other suggestions? as i have followed all the stop needed
                              thanks
