Set Zabbix Frontend to use HTTPS
  • idgykapow
    • Mar 2010
    I was wondering if there are any instructions to setup Zabbix so that the frontend uses HTTPS instead of HTTP. We are running Zabbix on Ubuntu/Apache.
  • Tenzer
    • Nov 2007
    • 316
    There are many generic Apache SSL guides spread all over the internet, you should be able to find one which matches your requirements.
    • Tim S
      • Jun 2006
      • 13
      I think most of us can figure out how to serve up Zabbix on an https:// port.
      But I think many people don't want to take the CPU hit on encrypting *everything* Zabbix wants to send via the browser.
      It would be good (and I think I remember this request from years ago) if there was a way to just use https for the authentication page (to avoid clear-text passwords on the wire). Once authenticated, plain old non-encrypted http would suffice (for me anyway).
      Is there a way to do this?
      TIA
      • Tenzer
        • Nov 2007
        • 316
        I guess that you could set up some rules for Apache which could redirect to a HTTPS page for the login URL, and then back to HTTP for the rest of the page. I don't know if the session would be transfered cleanly between the two protocols though.
