Questions on iten creation
  • Nyarlathotep
    • Jun 2007
    Hi to all.
    When I create a new item I got some starnge things. I've defined a "user-defined parameters" called voip.amount
    This is the entry in zabbix_agentd.conf
    UserParameter=voip.amount,/usr/local/zabbix/scripts/kebu_get_data
    Then I create a template: Template_VOIP
    Added item to Template_VOIP (view attachment)
    First: why I don't see application in textbox?
    zabbix retrieve correctly the value I need, but when I watch at the graph it says me there is no data. Why?
    Thanx
