Best Way to Uninstall Zabbix??
  • webtechengineering
    • May 2010
    Hello !
    New to the forum here and new to Zabbix...I can see the huge potential to use the system but I am having some issues and I would like to start over with a clean installation.
    Sorry for the dumb question, but what is the best way to uninstall Zabbix so I can start again?
    Thanks in advance - best regards from Houston, TX !
    Raul
  • nelsonab
    • Sep 2006
    • 1233
    Hope all is well down in the town designed by an Aggie, because only an Aggie would put the Belt outside the Loop. (For everyone else, if that makes no sense to you, it's a uniquely Houston Texas joke).
    There is an uninstall target which looks like it tries to remove the install binaries "make uninstall" (run it as root). Otherwise it's just a simple matter of deleting the binaries and the /etc/zabbix/ directory. Zabbix is very light weight in terms of what it puts on the OS. After you delete the files you will want to remove the Zabbix db which is just a simple matter of "drop database zabbix;", or replace zabbix with the name of your DB. If you really want to get everything delete the user you created to access Zabbix if you did.
    RHCE, author of zbxapi
      • May 2010
      that's a good one....are you from around here by any chance?
      thanks for the reply. I'll give it a try...
      Regards - Raul
      • nelsonab
        • Sep 2006
        • 1233
        Negative, lived there for a few years on the Southwest side.
