Empty box by executing ping / traceroute
  • mawoh
    • May 2010
    • 18
    my problem is about executing scripts in the map.
    when I choose a system and execute ping or traceroute, I don`t get a error-message, I only get an empty box. Look the attachment.
    Everybody has permissions for ping and traceroute. I also tried fping. when I start a terminal session, I can use ping and all the others commands.
    I use Zabbix 1.8.2 on an Ubuntu 10.04 server.
    Please help.
  • mercy
    • Mar 2006
    • 14
    check path to ping and traceroute utility
    whereis ping
    whereis traceroute
    and fix it Administration -- Scripts if needed
    • mawoh
      • May 2010
      • 18
      thanks for answering,
      the path was set correct
      /bin/ping and /usr/bin/traceroute
      and from commandline I can execute the utilitys, but it still don`t works.
