Question from beginner :( save the config
  • avrilspirit
    • May 2010
    I used Zabbix since 1 week ago and i have some problem.
    I downloaded the Live CD/DVD (iso), and it’s works but when it start it try to find DHCP server… We have’nt DHCP in the firm…
    I put : ifconfig eth0 192.168.0.180 ==> it’s works.
    It's possible to attribute an IP and where ?
    After I configured my computers for monitoring but if my Virtual machine restart I loose everything… it’s normal ?
    I tried to remove the iso when it’s started but if I launch the machine, it’s doesn’t works…
    I tried with the vdmk but it's not compatible with my ESX and VMware converter won't to transform the vdmk.
    Can you help me, please.
