Zabbix crash after launch on freebsd 7.3
  • Evil
    • May 2010
    • 14
    Hello people :-)) i need help. I run zabbix on freebsd 7.3 but always crash.
    sqgw# /usr/local/etc/rc.d/zabbix_server start
    Starting zabbix_server.
    sqgw#
    sqgw# tail -n 1 /var/log/messages
    May 16 11:47:55 sqgw kernel: pid 7951 (zabbix_server), uid 122: exited on signal 12
    sqgw#
    in logs files clean.
    sqgw# cat /var/log/zabbix_server.log
    sqgw#
    Configuration zabbix
    sqgw# cat /usr/local/etc/zabbix/zabbix_server.conf | grep -v #
    NodeID=0
    LogFile=/var/log/zabbix_server.log
    DebugLevel=4
    PidFile=/var/run/zabbix/zabbix_server.pid
    DBName=zabbix
    DBUser=zabbix
    DBPassword=ZabPass123
    DBSocket=/tmp/mysql.sock
    full version
    sqgw# uname -a
    FreeBSD 7.3-STABLE FreeBSD 7.3-STABLE #0: Wed May  5 13:08:33 EEST 2010     :/usr/obj/usr/src/sys/IPFWGWKERNAT05052010  i386
    sqgw#
    builder info
    sqgw# make showconfig
    ===> The following configuration options are available for zabbix-server-1.8.2_1,2:
         MYSQL=on "Use MySQL backend"
         PGSQL=off "Use PostgreSQL backend"
         SQLITE=off "Use SQLite backend"
         IPV6=off "Support for IPv6"
         LDAP=off "Support for checking LDAP servers"
         JABBER=on "Use jabber media type"
         FPING=on "Use fping for pinging hosts"
         SSH=on "Use libssh2 for SSH-based checks"
    ===> Use 'make config' to modify these settings
    sqgw#
    on attached files have debug info.
    Thanks for help :-))
