passive monitoring of firewalled systems
  • modonnell
    • Apr 2010
    • 17
    We're evaluating Zabbix for use where we have clusters of
    workstations (mostly Windows boxes, 3-10 per cluster) deployed at
    multiple (between 100 and 1000) customer sites where we have little
    control over their WAN configuration except that we can assume each
    workstation has the ability to establish NAT'd outbound connections
    on port 80 since that's already what HTTP typically uses.
    We'd like to deploy Zabbix such that each workstation at each
    site is responsible for pushing its own monitoring data back to
    the Zabbix server at HQ via inbound connections initiated by each
    machine as we'll not be able to initiate outbound connections from
    the server since they'd be blocked at the customer's firewall.
    We do *not* want to require each customer to have to open ports in
    their firewalls for us.
    Is this something Zabbix can do w/o requiring much surgery?
  • richlv
    • Oct 2005
    • 3112
    zabbix active agents would be what you want - they are connecting to the server.
    if only port 80 is available, you might have to forward that port to zabbix traper port on the zabbix server (or somewhere before that)
