procload on AIX
  • hjb
    • Dec 2004
    procload on AIX
    I would like to monitor procload values on AIX. Zabbix-server is a Linux-box under MDK 10.1. According to the triggers list, this is not supported on AIX. So I wrote the following script for zabbix_sender:
    export LANG=C
    set $(uptime | tr -d "," |awk '{ printf("%s %s %s", $10, $11, $12)}')
    /home/beckers/zabbix-1.0/bin/zabbix_sender ls0002 10001 testrocload $1
    /home/beckers/zabbix-1.0/bin/zabbix_sender ls0002 10001 testrocload5 $2
    /home/beckers/zabbix-1.0/bin/zabbix_sender ls0002 10001 testrocload15 $3
    Zabbix_server is ls0002 and my AIX-box is called test.
    zabbix_trapperd.log on ls0002 shows the following (debug=4):
    007708:20041202:090654 Length [7]
    007708:20041202:090654 Sockfd [1]
    007708:20041202:090654 After write()
    007708:20041202:090654 Before accept()
    007709:20041202:090654 After accept()
    007709:20041202:090654 Before read()
    007709:20041202:090654 After read() 2 [21]
    007709:20041202:090654 Got line:testrocload15:0.10
    007709:20041202:090654 In process_data()
    007709:20041202:090654 Executing query:select i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.va lue_type,i.trapper_hosts,i.delta from items i,hosts h where h.status in (0,2) and h.hostid=i.hostid and h.host='test' and i.key_='procload15' and i.status=0 and i.type=2
    007709:20041202:090654 In DBnum_rows
    007709:20041202:090654 Sending back [NOT OK
    007709:20041202:090654 Length [7]
    007709:20041202:090654 Sockfd [1]
    007709:20041202:090654 After write()
    007709:20041202:090654 Before accept()
    Any hints?
    Yours
    hjb
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Type of the item must be "ZABBIX trapper".
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • hjb
      • Dec 2004
      Hi Alexei,
      Thanks for your prompt response.
      I changed the "Type" for this item for this host (test) to zabbix trapper,
      but the error remains. Under last values for this host I have 3 lines
      with the descriptions (procload{5|15}) but without values.
      Or do I have to create completely new items?
      Would I be better of with an UserParameter-extension to zabbix-agent?
      BTW: The documentation for zabbix_sender in Manual.pdf is wrong:
      EXAMPLE:
      zabbix_sender oracle.company.com 10001 zabbix.companycomrocload 2.34
      According to the text below the example, it should be:
      zabbix_sender zabbix.company.com 10001 oracle.companycomrocload 2.34[/I]
      Yours
      hjb
